Hi
Hope someone can shed some light on this.
I have dusted down my old tape deck and connected it to the pc to digitise my cassettes. The cable I used is rather basic and the 3.5 mm plug that fits into the line in on the pc is a loose fit so I decided to buy another cable but the 3.5 mm plug on the new cable is also a loose fit. I’ve tried them both also on the laptop line in and that is also a loose fit.
Is this a typical problem with this type of plug, or perhaps the problem is with laptop and pc line in sockets?
thanks
