If anyone wants a source for individuality configured USB cable you can try Elijah Audio.
The prices are not at Chinese mass-market rates but they aren't crazy either for handmade cables.
http://www.elijahaudio.com/products.html
Found the same at a previous get together, we tried several usb cables between a laptop and v link. All were easily discernably different.
I really don't want to rock the boat (too much), but next time you do these comparisons, could you, for a giggle, try listening totally blindfolded so you have no idea what the cables are and/or how much they cost. All reputable USB cables at sensibly low prices have to meet a data-transfer minimum standard I believe and, until the data reaches the DAC, it's not supposed to matter. The DAC receiver has a "window of acceptance" which USB cables *should* be able to place the data in, so if one cable really is sounding better, then there's something else going on. Trust my ears? Not on my nellie, let alone yours
At our last bake off a chap showed up with some homemade USB cables which did not contain the power strands. His argument was lower noise by removing the unnecessary power carrying wires to an independently powered DAC. Don't know whether this logic holds up but I do wonder why all audiophiles are not using them if we don't need to power a component by USB.
Thoughts?
One of these days... I'm going to cut you into little pieces.
Yes and no, Yes it should not matter but somehow it does. The USB spec does give guidance on construction and impedance but there is quite a large tolerance on this IE: the twist per inch for the data lines has a 2 cm tolerance, the termination values have a 10% tolerance plus the data lines have to operate not only in differential mode but also support single ended command mode. These two modes have different impedance requirements.
The design of the end node device may use the defined USB specification for termination and impedance but many cables, even, spec compliant ones, will vary from the ideal. IE the TPI of many cables it twice that of the USB spec. and running the power lines inside the same sheath along with the twisted data lines causes variation of the impedance along the cables length. This last point alone may explain what shortest is best.
It may, as the differential pair run inside the same sheath as the power lines the cable twist of the data lines cause a varying impedance down the length of the cable. Removing the ground and Vbus power line would help and maybe remove noise from those lines. I've certainly had good results using a USB isolator and employing a 5v battery to power the Vbus line.
I'm fuckoff.
Best not tell anyone what your new DAC cost mate they will all have a hissy fit
I'm Paul.
I'm with Clive's approach on this as it makes perfect sense and have read similar results in using short cables or a cableless USB connection elsewhere. It has more to do with quality of connection and implementation than cost. I imagine the Mdac Martin used previously is not as great as the hype suggests and am sure that there are ways of achieving equally good results using some lateral thinking with reasonably priced components. Can't see why a DAC should cost £KK's or a simple cable £00's to achieve improvements over some of the real world products out there.
Paul.
