Originally Posted by
Beobloke
Certainly that's one possible explanation. However it might also be because of the tiny possibility that there IS no difference...
Most likely this.
If your wires are 2mm thick or more and everything is done up tight with the correctly rated fuse, and all your contacts are clean there's probably not much more to be gained, certainly there's no scientific proof that any audible differences exist from mains cable upgrades.
Of course swapping out a 3 amp IEC cable that's feeding a 200 Watt class A amp might well lead to an improvement.
