Just upgraded my Mains block from Lidl to MCRUS block. Which piece of equipment would benefit most from a new mains cable Just got kettle leads attached to most at the moment.
Your kettle. It'll boil faster.
I went on the assumption that the one that draws the most current will benefit the most. So for example - Power amp - Pre amp - source.
I suspect someone will disagree though...
In - Tweaked Lenco GL75, Linn Ittok, Ortofon Cadenza Black
Through - Croft Micro 25 RS LS, power R monoblocks, RIAA R. Ortofon ST-80 SE SUT.
Along - Tellurium Q Ultra Black cables
Out - Harbeth SHL5 Plus XD's
Street photography
Dave
Why not buy a lead and try it on items? Let your ears be the judge. I did and it made no difference on the amp. I gave up. It may transform your system
If the block is a linear type, with the sockets on a bus-bar system, then the source usually goes on first in the row, and power amps later. Try it and see if you can hear any difference, which when I tried it was bigger than changing one kettle lead for an expensive foo one with wanky plugs on each end which may not meet European electrical specs for all I know..
I've read somewhere that the source components should benefit the most, I've currently got my CDP and DVD fitted with Belden from MCRU. I can't say I've noticed a discernible difference TBH, perhaps a little more control to the sound.
My own logic would suggest doing the amp first, if there's any RFI/EMI getting in there it's going to get amplified. The reason I haven't done it yet is, it's hard wired so involves taking it out, case off and soldering
John
To be honest I am not expecting to hear a great deal of difference with changing power leads.
Will try positioning different equipment on new mains block first and see if that makes a difference then maybe get good quality power lead and swap it with the cheap lead on each component and see if it makes a difference. By assessing each piece of equipment I can ascertain which one benefits the most.
