Granite has a denser mass than slate so presume this would make it more inert.
However this fact may not translate into it being a better material for resonance isolation. The only absolute way to be sure would be to try two plinths made up from each material.....ahh expensive experiment:
I'm ChrisB.
The received wisdom about slate is mainly utter, utter loblocks!!
This is what I understand to be the case:
It is not a layered structure, despite what people think. It is laid down as sediment in a random fashion and not in layers. The reason it is easily cleaved along a relatively flat plane is not because of naturally occurring layers, but because when you split it, the shock waves travel along the line of the force that you apply. In this medium, you get a good clean, flat split because the particles that were deposited were laid down under a relatively even force and they are of a relatively similar diameter due to the force of the water carrying them.
That's not to say that it's not a good material to make a turntable plinth from. It's not to say that the way slate is laid down is not good for making turntable plinths from either, but sometimes people base their pseudo scientific theories on misinformation.
I'm Mark.
Neither. Quality wood is best:
http://www.layers-of-beauty.co.uk/Page2.html
I still like slate, and consider it a good material from which to make a turntable plinth, but I'm coming more to the conclusion now that high-quality wood, executed in the right way (preferably with some other material sandwiched in between), is the way to go.
That's probably the way I'll go when I buy one of Audio Grail's grey hammerite finished fully-restored 301s (as a second T/T)! I want some nice ebony
I'm Mark.
I'm ChrisB.
My thoughts are that wood combined with slate could be very good indeed and that's the way I'm heading with my G99 plinth. The wood part is mainly done but slate will be 'bread' for the sandwich.
So as I tried to point out above, I still think it's a good material but sometimes it winds me up when we are so ready to attribute our (perhaps misinformed) theories as explanations for differences in sound quality.
I tried birch ply CLD plinths in various configuations. All had something special but all had dowsides too. I'm sure wood with extensive development and auditioning would work well with a 301. When I tried slate it was immediately "right". Maybe this was luck but I suspect slate is simply easier to get right first time.
