I would say that, of those you mention, the CD player is the least sensitive. However, some valves are much more microphonic than others.
When you look at the approaches taken by manufacturers there are a number of common, but disparate, themes.
There are those that seek to isolate the equipment from external vibration (as per a turntables suspension) and there are also those that claim to channel vibration away from equipment. Within those two ideologies there are also two main design approaches.The first is to use compliant mounting, springs or rubber bushings (Sorbothane); the second is rigid coupling, spikes etc.
One thing is for certain, by far the highest amplitude of vibration that any component sees is generated by ones speakers. The amount of vibration generated internally (except by speakers) is very small and if the transformer is in another box (as it is with some phono-stages and pre-amps), the level of vibration generated is practically (quite possibly literally) non-existent.
However, as I said, vibration is still evident. If one places a hand on various components in my system, whilst music is playing, significant vibration can clearly be felt on the cases.
