How to get speaker plugs to fit better
I noticed the speaker cable plugs going into the Naim power amp were quite loose.
They are just under an inch long so have reasonable contact.
I assume better will be better sound quailty
Yes a proper fix is required but what can I do in the meantime to tighten them up a bit ?
Mike
