Originally Posted by
hifi_dave
IMO, you should have the large lumjps - power gen and NAP 500, on the bottom shelves. The CD player and turntable of choice, should be properly supported on top shelves, where you can get at them.
The phono stage, x'mer and pre should be away from large lumps generating lots of 'hum'.
Finally, cables should be tucked neatly out of sight..
Just bit more width and I could put the P10 on it's own low down table.
The plan was to have it above the 500 but the weight and the tight fit persuaded me out of that.
Size of the kit and cable lengths dictates too many positions
Tailor made could get around that, plus the Naim 82 and therefore HiCaps could be moved on
Mike
