Hi Tony.
I suspect that Marco and Dave Cawley are the two Analogue Gurus most likely to be able to offer constructive comment on performance (cue barrage of abuse from other knowledgeable AOS members), and I'm sure they'll spot your thread and reply in due course.
The only thing I can offer is that I've just swapped a Denon 304 for an OC9 and found the AT to be significantly better, or at least more to my taste than the Denon.
One thing you might want to bear in mind, is that assuming you're looking at the 33PTG as an import (I've not seen anyone retailing in the UK, but I could be wrong), you may well get hit with import duty etc and Dave C will do you an excellent price as an AOS member which slashes the difference and means you have the support of a UK distributor.
I've also heard that the suspension on the 33PTG is designed for a higher humidity climate, but I have no idea if that is the case or whether it's a significant issue.
Steve aka 'Twelvebears' (it's a long story)
System: Technics 1210 Mk5, Jelco 750 arm, AT33EV via MF X-LP2 Phono Stage, Oyaide mat and record clamp. SB Touch via Marantz PM-11S1 amp and Wilson Benesch A.C.T. speakers. Mark Grant cables and PS Audio Power Plant Premier mains regenerator.
(\__/)
(")_(")
