I have noticed a few people recommend twin and earth mains cable for amp/speaker connection. Presumably the stuff for lighting is good enough.
Anyone tried it and got any thoughts?
Yes-I am a skinflint
Jerry
Hifi: IPL transmission line floorstanding speakers, Squeezebox Touch, Denafrips Ares 11 DAC, DCB1 Pre-amplifier, Croft Series 7 power amp.
Custom Hifi cables HA10SE headphone amplifier and Hifiman HE-400 headphones.
AV system: LG 55B7, Denon AVR -x2300w receiver, Quad 12L (front) 11c Centre and 11L rear . Velodyne DD15 subwoofer.
Warm, full and quite musical, hard to dress, but for buttons pretty good, put plugs on the ends, as the bare wires are lethal to equipment and hands alike.
Me so horny- Impulse H6 Horny
Copper can be dirty and it's a pita to terminate, but can work really well if you have a freshly manufactured run.
6A twin mains cable works well in shortish runs (5m or less) and with non-foo gear the real world buys
Good, I have tried a few cables recently that I don't think much of so I am going to try some mains lighting cable I have found in the garage. It's 1.0mm twin and earth 14amp. It will need a clean up first to get the cobwebs off!
Jerry
I'm fuckoff.
Have you tried Black Rhodium Twist?
Meant to be good bang for the buck.
Jerry
The Twist and the Rega Quattro are both good value . What length do you need ?. I've got 2 x 2metre lengths of each which I can send to you to try out Jerry . Think I may have some NVA LS2 in longer lengths . PM me if you're interested mate.
Thanks Brian-PM sent
Jerry
Amplifier:
Sony DA-2400ES
Sources:
Technics SL-PG490 CD Player
Pioneer N-50 - Network Streamer
Sony MDS-JB940 Mini Disc Player
Sony BDP-S360 BLU RAY
SKY HD 1tb Box
Speakers:
Paradigm Monitor 7 Monitors
Paradigm Centre
Mordaunt Short Rears
Cables:
Tellurium Blue speaker cables with bridges
and terminated with Z plugs
Black Rhodium twist.
Yet again +1 for the twist at the price its a no brainer.
