Got this on eBay for £230-something delivered. Arrived yesterday. Many folks seem to rave about World Design kit, and I've had my lovely Meitner solid state pre for, oooh, it must be months now, so I couldn't resist when this little pre came along!
As many folks here will know, these usually come as kits from WD (although they will make them up for you for a fair price). This was a kit one and to my barely competent eye seems to have been well put together. Just as well I didn't try to build a kit as it needs someone who'se actually competent with a soldering iron and can be trusted not to burn his house (and probably the rest of the neighbourhood) down as part of the kit construction process .
More inputs & outputs than an AV receiver!
And here is what it is up against in Chateau Jerry, my Meitner PA6i, hailing from Canada ....
Call the WD Pre2 a valve amp, though? One little ecc82 sitting pretty in the middle of the pre-amp module and that's it!
Solidly made, quite hefty, and looks dead cool on the rack. A little bit of blu-tack over the searchlight beam (aka the blue LED) and all is OK.
One slight oddity, maybe, is that sound only issues forth when the little switch in the middle of the fascia is on 'tape' rather than 'source'. Did the guy wire that up wrong or are my expectations wrong? Whatever, seems to work AOK with the switch flicked downwards.
The sound? Well, if I'd had to guess which was the valve pre from the sound I'd have chosen the Meitner solid state. The WD Pre2 is really explicit, with very tightly focussed images and quite an 'exciting' sound - I suspect there is a slight treble edge, although this calmed down after a half hour or so (or maybe I got used to it). Clarity in abundance. Female vocals are a real treat! I played a mono LP of a string quartet, and for the first time didn't hanker after stereo to help separate out the four instruments - the WD pre laid it all bare in mono. Nice, and very impressive.
I don't know what make the valve is yet, but a little tube rolling might not go amiss here (good fun anyway!). Perhaps a vintage Mullard? (I've my eye on one on eBay ).
Really enjoying this on my first few hours listen, as it seems to complement my Bel Canto eVo4 power amp which is a tad on the warm/'musical' side of the fence. But can I live without remote control of volume .... ?
