Hi folks,
I wanna post my mod to this well known dac
replaced psu caps with 3 panasonic FM 2200 uF
replaced 1716 decoupling cap with sanyo OSCON SP 100 uF 10V + .33 uF MKT
replaced opamp decoupling cap with rubycon ZA (ultra low ESR) 100uF 35V + .33 uF MKT and the cap behind with one panasonic FM 1000 uF
added 2.2 uF MKT to bypass both 7810 and 7805
replaced opamp with AD8620
replaced opamp output cap with mundorf mcap 4.7 uF 400V
replaced opamp input cap with mundord mcap 2.2 uF + rubycon ZA 22uF 35V
replaced opamp FB caps (C5 and C6) with 1nF MKT; I've had to increase value from the original 220pF to 1nF to smooth out the over brilliant and sharp ad8620 sound signature
the result?
coupled with my DIY amp based on tripath TA2020
AMAZING !!!
deep, warm and rock solid bass, clear and open midrange, super detailed highs
the sound stage is spectacular, I can not just listen the music, but also look at the instruments materialized in the air, loudspeaker simply disappear
hours listening at volume high enough to disturb neighbour without any ear fatigue, just an unlimited pleasure
for the first time in my life classical music make sense to my ears, is alive, full of energy
I've just a question for you experienced guys: I replaced also the ceramic cap above the opamp with a .22uF MKT; is probably the V+ V- bypass I guess, but I'm not sure about the effect of different capacity
the larger the better or whatelse?
