I'd really love to try one of these things. I'd be happy to shell out what is a massive amount of dosh if I KNEW it would bring big improvements.
I'm Harry.
Harry, do you trust my judgement? If so, I can tell you that, outside of a major component upgrade (such as with your Ushers), the Ultimates will provide the most astonishing sonic improvement in your system, such as you won't quite believe until you hear it...
Wanna hear those top-notch recordings of yours in (truly) all their glory? Then fit a 'stiffy' or two!!
Mike
Speak to Kevin at Signature
He will arrange for his local guy to loan you one I'm sure
I didn't bother with much investigation on the first night as I didn't think it could be that good from cold and new.
The improvement in sound makes you stop
the P10 is one of the biggest single improvements I have ever heard
Put a stiffy on the front end and you have heaven
Mike
Mike
As the P10 didn't give me enough clearance my the oversize Mana rack it had to go on top
Therefore the Isis instead of being on a Mana Ref top, on top of the rack is now in the middle of the rack
So even with that drop in position and sound quality it still way out performed the previous set up
Mike
To add to Mike's observations, my P10 was a big leap up from the PPP, itself no mean regenerator. My household mains suffers from high voltage flat-topped sinewaves, anything from 248 - 252V at between 3 and 5% distortion. This is typical of most mains waveforms in my experience, few people are lucky to have a low distortion supply. What the P10 does is supply an immense amount of immediate-demand current to maintain the voltage no matter what the system is doing by lowering the incoming supply impedance, at an output distortion of 0.6%.
As Mike says, the sense of music coming from darkness, pinpoint focussed soundstage and subterranean extension to the bass transforms a good system into a great one. Worth the amount you might otherwise spend on upgrades once your system has reached a certain level of capability.
I too use a 2.6mm Furukawa 'Ultimate' input cable.
I'm Harry.
Mike
Mike
