Hi,
I'm looking for Solid Speaker Cable like Cyrus High Purity Solid Core (the old ones in grey color)... It could be any brand with that topology...
Thanks
I'm José.
Hi,
Thanks
I'm ChrisB.
H, Kim,
I've got some of that Cyrus solid-core in a box with a heap of valves & stuff. If my memory serves me correctly though, it's a very short pair - 1.5, maybe 2 metres per channel. Come to think of it, I also have a pair that's longer than I need that's hooking my Tannoys to my Yamaha receiver in my 2nd (or is it 3rd.........or 4th sytem- don't know how long they are either!!) - I could probably swap those for the short ones if you needed more . Let me know if you're interested & I'll have a measure up & let you know how much there is.
Obviously there would need to be a small consideration involved!
Cheers
I'm José.
Cris,
Thanks for the reply...
I'm realy interested... please send me measures...
Regards
José
I'm José.
Hi José,
Don't despair, Chris is a busy boy and so pops in and out. Rest assured he'll come back with the measurements soon on his next visit - he's one of our regular contributors
I'm ChrisB.
Jose,
I'm sorry, I've been unable to get to the cables. I promise I will get back to you asap.
I apologise for not keeping you informed
Speak soon
Chris
I'm José.
Thanks Chris
I'm José.
Hi,
If anyone have this cables to sell... please tell me...
It could be also Mission Solid Core (old ones)
Regards
I'm ChrisB.
Do you mean by 'solid core', a pair of single conductors? If so, then DNM make some solid core quadrifilar (4 separate conductors) ribbon speaker cable, intended for bi-wiring.
Or, you could try 20A twin and earth mains cable (ignore the earth conductor). Cheap as chips, although stiff, but then I doubt that the Mission Solid Core cable is particularly flexible. Michael Hughes raved about the use of mains wiring cable as speaker cable many years ago.
Regards
