Sadly thats the condition they were in when purchased
But the sound more than makes up for the cosmetics
May see if I can make some stretchy covers for them in a more acceptable colour to me
I'm Allen.
Take the grilles off and 'dolly' out the kinks. Shouldn't be too hard.
They do sound nice. I had a pair. Had to rebuild the rectifiers in mine.
I'm Allen.
I'm Allen.
Just found this on the web a review of the 35 year olds
" These speakers were manufactured in the '70s... yep, 35 years ago... Then, why this review? because their technology was very special, and still interesting.
The mid-bass was 7.5", huge magnet, cast frame, bextrene shallow cone.
They were loaded by a quarter-wave Transmission Line, and covered the spectrum up to 3kHz. The T.L., high crossover frequency, very thick baffle and Bextrene cone resulted in a very neutral, non-boxy sound, still excellent today. The efficiency was very low, though, and a powerful amplifier is required (100W per channel).
There were 2 dome tweeters, one 38mm and one 19m (above 14kHz). Dome tweeters were in their infancy, and use of 2 tweeters was logical at the time, but one 25~30mm modern dome tweeter today would provide a less harsh, more detailed sound.
I wonder if somebody ever modded a pair of B&W DM2a. Keeping the enclosure and the mid-bass, augmented by a modern top-quality dome tweeter with an adequate crossover, should be a killer combination.
It is a pity that T.L. are not used more often. The freedom from 'boxiness' and the possibility to produce very low bass from a mid-size woofer are exceptional. "
Dunno where you got that info, but they are 1/8th wavelength lines, not 1/4. I spoke to John Bowers about his design when they were released.
You not thought about getting those ESL 57 refurbished, Al?
I'm Allen.
I'm Richard.
Do yours have the wax potted EHT units? If so its a fairly easy DIY job to rebuild them with new caps and diodes. Assuming they are still stock then you are not hearing them anywhere near their best.
I have a spare pair here I always intended to rebuild and then sell on an exchange basis for old ones.
I'd recommend taking grills off, gently push out dings & wash them, check EHT units to see if they are wax potted & and clean all the dust off the panels (nappy wipes are good) - you can then also check panels for arc damage.
Richard
