Tony - I've got a real Bruil weight (manufactured by him). I find it gives bass some added weight and reduces surface noise. Weight is 380g so not too heavy for the bearing or motor.
Hi Martin,
the one I linked I chose not only for price (when the $AU was 97c US) but also because the dimensions were within Rudolphs recommendations, particularly in respect to mass, which is 13oz (368gm).
In conjunction with the Achromat I have found it to improve the resonance transmission properties of that mat (at least I assume that is what is happening) in that it improves clarity and separation, increases the "air", blackens the background and improves transient response and bass without sounding "bright" which I found acrylic mats to do, or dulled and leaden which I found rubber mats to do, rubber was very good for drive and transient attack and bass but sounded dulled, "rubbery" and slightly clouded at higher frequencies. I found the weight better than the michell clamp in that it is not necessary to push down to ensure full contact (possibly stressing the bearing) but is sufficient to give a good contact between the record and the achromat and press the thin (3mm) achromat (chosen for increased flexibility) onto the silicone and overcome (I imagine) the slight concavity of the Technics platter.
Reduction of surface noise is also a feature of the combination. (and perhaps also of fast wideband phono stage response)
It is always good when a tweak gives an audible improvement, n'est ce pas?
TG
Intel NUC/Chevron Audio NDF16 dac/Amptastic Mini-1/Audium Comp 5
Mains Block: Custom-HiFi-Cables PowerBlack Distribution Block (with super conditioner).
Connected with Reference Fidelity Components Super Neptunes and Speaker Cables.
Powered by Custom-HiFi-Cables DC2 psus
Peter,
some parts have had a deal of rain, it is a fairly sizeable piece of ground - I am a good 8 hours drive from any of the borders but the wet one - more than sufficient space to allow significant variation in local climatic conditions, your brothers experience does not surprise me - I think our main catchment/dam is still well below capacity from the recent prolonged drought.
