Page 1 of 6 123 ... LastLast
Results 1 to 10 of 53
Thread: Software media players tricks and tips
    Default Software media players tricks and tips
    As mentioned in passing in another thread, this one is for users to mention any tips and tricks useful for media players like JRiver, MediaMonkey, Foobar Winamp etc. that they discovered or picked up.
    I'll start off with the memory buffer in Media Monkey. I am using version 4.0.3 as a reference.
    If you go to Tools -> Options -> Player -> Output plug-ins, you'll see a listing on the righthand side that shows you the available output plug-ins. I haven't installed the ASIO plug-in yet, but the OutWave plug-in has turned out to be very useful for high bitrate files. If you highlight it and then click on the Configure menu option just next to it, a new screen will open up. In that screen you have various options. Try them out, but the memory buffer increase is the one to pay attention to. I use 2000ms for the Buffer length, which has allowed me to play some difficult high resolution files. Because some of those files are 100MB or more, compared to maybe 40MB for a 16 bit/44.1KHz file, it is quite easy for the playback to suffer from buffering issues and reduced playback quality. You can mess about with the various buffers and then play some large files to compare. Once you hit the right spot the PBQ available is tremendous.
    I'm Will.
    Good stuff Stan...
    As a general concept with all windows based players;
    Set the windows sound scheme to ‘sounds off’, set the onboard soundcard as the default sound device (your music player will be configured to use your DAC or whatever), and set all device volumes to maximum
    Ok my player of choice is Winamp, which when configured correctly is excellent IMHO
    Options/Preferences is where all of the important stuff occurs...
    General Preferences - Set 'Priority Class' to high
    Playback - Check the allow 24bit box (if you're using high res, replay gain, or upsampling)
    Playback/Replay Gain tab - Uncheck this box (if you want to use RG it's better via FFSoX), also uncheck the 'ask before writing RG' option as this can become very tedious when RGing a lot of albums
    Local Media/Watch Folders tab - Define your music directories here, the rescan option will identify any changed/new music, without having to completely refresh your catalogue each time.
    Plug-ins/Input - If you are using FLAC with ASIO there is a known bug, gapless doesn't work properly, (WASAPI works fine on W7). The solution is to use the FFSoX plugin available from
    http://in-ffsox.sourceforge.net/
    This is an excellent plugin, which will transcode from FLAC (amongst others), and optionally allow real time upsampling to 24/192 and all points in between. At the same time it can be used to apply ReplayGain if required. Because it transcodes the data stream prior to hitting the Winamp player the gapless issue is eradicated. I tend to use it with no upsampling, no ReplayGain, no dither, no limiter for best SQ, but this depends on one’s preference and DAC.
    Plug-ins/Output(For XP) – Use Otachan’s ASIO out .dll available from
    http://otachan.com/out_asio(dll).html download, unzip, and drop the .dll into the program files/winamp/plugins directory. This will give you an ASIO output option in the Output plugins list. Select your device driver from the dropdown list ASIO4ALL if you don’t have any specific drivers, set the ‘thread priority’ to highest, buffer size to highest, and select gapless, no resample. N.B. If you are using an ASIO driver eg. ASIO4ALL set your buffers to the highest level in there too.
    Plug-ins/Output(For W7) – Use Maiko’s WASAPI out .dll available from
    http://maiko.elementfx.com/ same process as with the ASIO .dll above. Turn off volume control, and give WASAPI exclusive control of your output device. This is why it’s best to set the onboard soundcard as your default soundcard, thus preventing any contention in the usage of your DAC etc. Set the buffer size to the highest available value.
    DSP/Effect – Ensure that this is set to off.
    Err that’s about it I think…oh apart from be careful when installing, don’t set AOL as your default browser, don’t have the 50 free mp3s, don’t allow anonymous usage statistics, and don’t subscribe to their promoted radio stations…other than that it’s a nice piece of software!
    Enjoy
    Cheers, Will
    I'm Neil.
    Thanks guys for doing this - great help to newbies like myself
    Regards Neil
    For those using Windows Vista/7 who may have missed it, the WASAPI 3.0 driver for foobar has now been released.
    http://www.foobar2000.org/components...foo_out_wasapi
    Version 3.0 has lost the flakiness of the earlier version 2.1.
    I use it in 'event driven' mode. I use a buffer of 540 ms and it plays faultlessly with no gaps in the sound (into an Audiolab 8200CDQ).
    The installation instructions are nonsense. You cannot install the new component by double-clicking it. If foobar does respond, it will try to play the file. You also cannot install it by clicking 'Install' in the 'Components' page of the foobar Prefs as the file type is not recognised and so it doesn't appear in the list. The only way to install it is to drag the file to the list of components, click OK and let foobar restart. Then go to the foobar Output Prefs and select 'WASAPI (event): <name of your DAC> ....'
    I don't know if the old WASAPI component is removed by the installation so you might want to go to the components folder ( C:\Program Files (x86)\foobar2000\components ) and delete it (while foobar is not running of course).
    iFi ZEN Stream/TV/CXC >> RME ADI2 DAC >> XTZ Edge A2-300 >> Rogers LS8a
    PC >> Hugo 2 >> iFi Pro iCAN Sig >> Raal-Requisite CA-1a
    I'm Will.
    ...might be worth making this a sticky
    Cheers, Will
    Default JRiver Media Centre
    I think JRiver media is really excellent now at Ver 18, download it from here http://www.jriver.com/index.html
    I built my own HTPC and installed windows 7 / Jrivermedia and it worked great with any output to my M2Tech Young Dac, Coax, Optical and Asynchronous USB which I think sound best.
    Once installed read this http://wiki.jriver.com/index.php/Getting_Started
    And the user manual http://wiki.jriver.com/index.php/Media_Center
    Couple of tips
    From the opening page go to tools and options
    Set up your Library only to automatically import music from your storage device, go to configure import I use a NAS drive so you just click add and link it to that I delete other links it automatically sets up like the C drive or any other comuters on the network which it will import music from if you allow it. I have all my music in FLAC so they are the only files I want it to pick up
    In the main page go to File, Library, Import and select run auto import now
    Click on the start up tab and select to automatically start up when windows starts so it boot straight into Jriver and all your Tunes are right there
    in output mode settings check that your sound device is selected, if you are using USB it should show in the drop down box
    In the options set the output mode to WASAPI - Event Style if your hardware will take it as this stops windows from using any of its processing like the system mixer, it goes straight to the output device if you get any tics just increase the buffer from 50ms to say 100.
    If you are using a sound card as an output then ASIO may perform better.
    If you do use USB go to your Dacs web site and get the proper driver.
    Don’t tick anything in DSP studio as you can end up up scaling or downscaling and processing the sound in some way. however if you have a DAC that wont play a certain frequency output (say88khz) then this can be useful to automatically resample this to another usable frequency.
    in settings select playback from memory instead of disc function as this buffers the music into ram and I think this sounds better particularly if you are streaming from WIFI but it does induce a delay on WIFI. I have my Nas hard wired with Cat6 so there is no delay in my system.
    I use a Samsung tablet as a remote control using an App called Gizmo it works great and I can access Jriver from other rooms
    http://wiki.jriver.com/index.php/Gizmo this is the instructions for setting up Gizmo on your tablet and in Jriver.
    If any of your cover art is not recognised just right click on it and select get cover art from internet, you can also edit the tag info as well
    Hope this helps
    Alan
    I'm Gary.
    You can get a a worthwhile improvement converting your Flacs to uncompressed format, noticable particulalrly if running Jriver.
    JRiver 18 is the most transparent, most "audiophile" player out there imo and shows up any changes you make quite easily.
    I tried Jplay, Cplay, XXHighEnd and...naa.
    Using Jrivers inbuilt tools try converting a Flac album to Aiff.
    Not Wav though, doesn't sound as good...
    Apple do the whole audio thing a bit better than Microsoft.
    (Aiff is Apple's version of a Wav file)
    Yup, I know Flac is lossless and theres checksums and all that good stuff to ensure the original signal is outputted, but its the extra CPU load when uncompressing Flac back to PCM than can have an impact.
    I've found that even with a powerful PC where you'd think this kind of thing would not matter it does.
    In my experience with computer audio, getting the software right can make as much difference as changes in hardware.
    Tweaked a mates server recently and the difference was quite a omg moment.
    His speakers are doing bass like they shouldn't, just because of software.
    Try converting a couple of favourite albums to Aiff in Jriver. It might surprise you.
    I heard it for myself in my system, enough so that I converted 5000+ abums to Aiff. A major PITA but worth it.
    Had to buy an extra 2TB drive mind you, but not that expensive in the scheme of things.
    try it for yourself though..its worth doing and it's free.
    AC POWER
    AMPS
    SPEAKERS
    Wharfedale Evo 4.4
    DAC
    TURNTABLE
    PHONOSTAGE
    DIGITAL
    MUSIC PLAYBACK
    Ipad Roon Remote.
    SPEAKER CABLES
    INTERCONNECTS
    Gazjam
    Ok thats very interesting Ill give it a go
    Alan
    I'm Nodrog.
    For us Mac fans, would it be the suggestion that converting all our Lossless files back to AIFF would show some advantage??? Seems illogical but I'll try anything once!!
    I'm Nodrog.
    Default Apple lossless to AIFF
    Well, I tried it and I can't say I noticed any difference. Maybe when I get my new DAC!!
    It did increase the size from 30mB to 50mB (short song) which surprised me as I can't see how it can create any information that isn't there. I guess, basically, I just don't understand the technical stuff.
    I just lurve the music.
