I have recently taken possession of a pair of Quad II valve power amplifiers and is seeking advice on a suitable preamp to partner these Quad II power amplifiers.
How good is the vintage Quad 22 preamp without spending silly money in upgrading the components for little gain in sound quality?
Not sure if it is worth the costs as I have read that the 22 needs a lot of work and a better option would be to go for a modern preamp from other manufacturers. My budget is a modest £500.
I am also exploring the options of possibly using ‘older’ preamps from the Quad stable such as the 34/44. Again these would need upgrading too for better sonic performance.
I do have an aging 33 that I can be using until a better preamp is bought for the permanent set up. However I am confused with how to connect the 33 to the valve power amps.
The 33 has 2 switched AC mains outlet sockets supplying power using a 2 flat pin (very similar to the American style 2 pin power plug). I assume that these will be fed to the Bulgin plug that is fitted to the Quad II valve amps.
The Quad II are also fitted with a single phono socket replacing the 6 pin Jones connector – Where do I connect this to the 33…..which Din input socket?
Another point of clarification regarding the power supply – would the Quad II be normally connected to the power socket and not directly to the 33 preamp if another brand of preamp was used.
I look forward to hearing your advice on the above. Thank you in advance.
Peter
