Try the xover at around 90hz or up to about 110hz, probably using a fairly steep slope too. 150hz IME is too high, fun but high!
I'm ron.
I'm ron.
hi Clive,
Are you running the berhinger DEQ as well?
I really have no clue what im doing and had a freind over who knows more than be but even this was a bit hit and miss with out a mic although he did get the bass drivers to stop doing the mid stuff. had no omni directional mic either so all by ear and to be honest it sounds bloody good but room vibs and the likes playing there part also.
I have no electronic experiance and am not very computor literate so this is frustrating to say the least. I cannot follow the intruction manuals either as i have no knowledge of what the hell they are on about.
Anyway is there an easy way to do this or is it a complicated process. there is a you tube instruction but for setting bass on a small speaker. Any help would be appreciated if you can.
Cheers
Ron
Hi Ron,
I used to run a DEQ. The controls and display do take some fathoming out. I can't remember much of it but in your situation I set it up to use the same settings for L & R, there's a away to preset this so you don't need to set everything twice.
Are you simply trying to set the xover freq and slope for now? Room modes gets a whole lot more complex and really needs a mic and measurement software.
There's bound to be a youtube tutorial somewhere.....I'll try to remember some of the details but I've used my XTZs for more than a couple of years now so my brain has forgotten the DEQ details....
What are the dimensions of your room?
Oh yes, one more thing to add to further complicate your setup. I use a 6db boost at 25, 31.5, 40, 50 and 63. This is needed to get a flat bass response.
I'm ron.
Just different, not better. I find them easier to setup but you need two Sub Amp DSPs and their Room Analyzer. Vic uses a Behringer digital amp with dsp, it's all in one box and is intuitive to setup. You'll need a room analyzer unless you have a well behaved room. Vic modded his amp as the fans were too noisy. I think it's an iNUKE NU1000DSP.
There's also the more expensive auto setup modules that Antimode make, I've not tried these but they should be easiest of all though maybe the most expensive too. http://www.bkelec.com/hifi/Sub_Woofers/anti-mode.htm
I'm ron.
The INuke is quite intuitive Vic uses NU6000DSP I use the NU3000DSP my drivers are harder to drive than the Neos but you need to speak to Vic about the mod he does to prevent fan noise with either version
This might help with the 2496 http://www.decdun.me.uk/deq2496.html
As Clive has said probarly some good tutorials on youtube too
I'm ron.
thanks john, a very good step by step i will have a good go at that and see what i get
