I'm Phil.
I'm Phil.
Looks like Rothschild doesn't frequent here anymore.
Anyway I fixed mine by striping a bit if litz wire out of an old earphone cable. I took the tonearm apart and ran the wire up the tube and out the bottom of the bearing.
I soldered one end to the earth point inside the connection block underneath the turntable. At the cartridge end I made a loop in the wire and coated it in solder. I put the loop around one of the nuts for the cartridge bolts and reassembled (had to scrape the paint off the nut a bit to ensure a good connection).
It now operates totally silently.
yeah not seen him post for some time.
I'm Phil.
I looked at pictures of the later Genie arm and noticed that they have a similar ground wire. It is attached to the underside of the tonearm (near headshell) via a small self tapping screw. So I've altered mine by drilling a small hole in the arm and attaching the ground wire Inthe same way.
