EVENING MARCO... KEEPING WELL ?
I tried lifting my cables of the floor years ago but could hear no difference...maybe worth trying again. However Speakers pump energy down cables because of being hooked to the back of them and also air borne too. Some form of de-coupling from the speaker interface would really be needed too ?Indeed, but it's the best solution because then they're only being exposed to one form of vibration instead of two or possibly three, if cables are on the floor and also touching walls.
Yes agreed...I find my Clear Light RDC Aspeckt Racks to be very good. Light frame (non Metal), resonant damping material in floor cones and in all the shelves. There is also a degree of looseness in the design too. Was fantastic value when they sold for £500 at I think £750 now not perhaps as good value but still very good tables and isolating products.The virtual elimination of the effects of the above is precisely the reason why I use multi-phase Mana supports. Quadraspire Reference acrylic and Townsend Seismic Sink supports are also highly effective in combating this problem, amongst others.
Anyone who does that is in for a truly earth shaking shock when they move it off and on to a proper table. Even using isolation platforms will be a revelation.That's why by simply dumping your gear on an old sideboard (or on something like that) will never result in the unlocking of its true sonic potential...
Regards D S D L ----Neil
