If the charger is the one I think you are buying then I'd say its not appropriate.
This is the sort you need to get:
http://cpc.farnell.com/ideal-power/a...cid/dp/BT03796
It has the correct charge profile for SLA IE: Fast, Normal and Float with auto shutdown on full charge and reverse polarity protection.
