I use a Squeezebox Classic and a Beresford DAC. I would not use the SB without the Beresford or another external DAC, but it depends on the quality for your HiFi. The SB will better an average CD player.
I notice no difference in quality or reliability between wired and wireless working - the bits get through just the same.
The SB does keep a potentially noisy PC away from the listening room, and does get a reliable bit perfect stream to your DAC.
Questions about SB are best asked here
http://forums.slimdevices.com/
Look here
https://www.ripcaster.co.uk/
Best prices seem to be here at the moment
http://www.cooltopia.com/
Brian
In Southampton: Raspberry Pi 4 running PiCorePlayer, Beresford Caiman SEG, Quad 77 Int Amp and CD Player, AVI Neutron 4, Sennheiser HD25 headphones.
In Nicosia: Small Format HTPC, Beresford 7520 ,Quad 405-2, Quart 980s German Tower Loudspeakers.
