Results 1 to 10 of 16
Thread: Cart purchase
    I'm Pete.
    Default Cart purchase
    Guys and gals,
    Looking for a new cart. Considering this:
    Any thoughts? Should I consider the 0.24mv or 0.48mv version? Silver or copper coils?
    I have a Pass Pearl Phono stage with about 55-60db gain, and my Candela preamp has another 12 db of gain.
    Hearing is believing
    SL-1210 Mk5 w/Mike New Platter/bearing/armboard; Hynes SR5 DIY PSU;
    Zyx Airy3X; SME V; Hashimoto HM7 SUT; CJ PR15MkII Phono w/teflon caps.
    Modwright LS36.5 Dual Mono Preamp & KWA 150 amp > Paradigm Ref 100 v.4s
    I'm ILOB.
    If you can afford this then go for it
    I have r100h which works really well in my system and heard the airy 3 which is pretty special
    Have a read of the following link
    http://www.high-endaudio.com/RC-Cartridges.html
    But I have no idea how it work with the tonearm you have it maybe worth waiting for a response from someone who has the same arm I am sure Marco my point you down a different road
    You should have enough gain to work well
    With the amount of gain you have, I'd go for the lower ouput version. And silver wire.
    Hi Pete,
    In your system, I'd definitely go for the lower output version as you have more than enough gain to make it perform optimally. This will do two significant things:
    1) Allow you to have proper control of volume, and thus maximise the full dynamic range of recordings.
    2) Less coil windings in moving coil cartridges (therefore lower output) means better sound quality - end of, providing the rest of the design is good!
    Fortunately, the ZYX is an excellent cartridge, and if I didn't have such a love affair with Denons, it is one of the few genuine hi-end designs I would consider buying.
    However, unlike Pete (i should coco) I would go for copper coils as they ZYX is already quite a 'clean and precise' sounding cartridge, so silver coils could tip the balance over the edge and create a more forward, 'etched' type of presentation, unless the sonic signature of your system currently is on the 'dark' and warm side.
    Enjoy!
    I'm Pete.
    Thanks guys.
    I have been unsure about the .24mv version. On my preamp with the Denon 160 (1.6 mv??) cart I currently listen at the 9 o'clock position, and the pot goes all the way around to 5 o'clock position, so I am thinking I have lots of gain.
    The silver is what I was leaning to, just not sure if I give up anything in terms of resolution, soundstage etc. According to what I've read and Sorasound (US Distributor) the silver is slightly warmer in presentation than the copper (usually the opposite is true).
    I'm Pete.
    They also sell a version with a silver weight (adds 4 grams I think).
    This looks alot like a standard cartridge weight that goes between the tonearm and cart. Not sure I want to spend the extra $100, for the Zyx silver one, when I have one sitting in my box of bits for free....
    I'm InSpace.
    Quote Originally Posted by Pete View Post
    Not always the case...
    With stranded silver plated copper it can be the case, but I usually find solid silver quite smooth.
    Cheers...
    Shian7
    Kudakutemo
    kudakutemo
    ari mizu-no tsuki
    Though it be be broken -
    the moon on the water.
    - Choshu.
    I'm Mark.
    "They also sell a version with a silver weight (adds 4 grams I think)."
    I bought a ZYX R100 -H-SB-Yatra (only option copper coils) with the silver weight (SB silver base) and high output 0.48mV.
    I needed the silver base to bring the total weight up to around 10grams , I use a Brinkmann 10.5 arm and 10g is perfect. the silver base is fitted into the cart and doesn't look like an add on weight.
    I use a Clearaudio balance phono stage 58db gain and the 0.48mV from the ZYX is good,
    just the right amount of gain for my pre amp so my CD and TT are at similar volumes.
    0.48mV is low compared to the Clearaudio carts at 0.7-0.8mV, I think for me the 0.24mV
    option would have been too low.
    Anyway the ZYX is great, best cartridge I have used, I bought it form Mehran at sorasound,he a good guy call him and he will get you a good deal.
    Quote Originally Posted by Mike Homar View Post
    That's absolutely true. There's a big difference between plated and solid, and even solid v. solid, depending on the purity.
    I'm Pete.
    Well after reading, and talking to other zyx owners, and mulling it over all day long, and having a long talk with Mehran as Sorasound, I ended up with:
    Don't ask how much it cost... way out there!!!
    But: source first, I always say
