Ron, may I dive in here?
By using an Ekos, in whatever state of tune, on a techie, and irrespective of the cartridge, you may just be on a recipe for disaster if the mounting plate is a metal one. The Ittok/Ekos arms ring at high frequencies to a greater or lesser extent and a direct coupling to an aluminium arm-plate botled tightly to the plinth *may not* be the best way for sonic bliss with these arms - just my thoughts obviously. I personally wouldn't use these two together based on instinct..... Oh alright, I was forgetting the Keel and Rubykon with the LP12 being solid aluminium but whether these would work with the cast top plates now being marketed for what's left of the original fruitbox is anyone's guess
OC9? Whatever posessed you sir? After a Koetsu Black, any AT moving coil is going to sound astringent to a degree - and this into Naim and SBL's too? Blimey, your lugs must be nearly as bad as mine Much as I like the crisp AT's in the right system, I'm really not sure about this one chez Jazzbones myself
I think the 750D is a great value tonearm, bearing in mind the stupid prices asked for anything regarded as "top end..." these days. Once you have it back from Johnnie (I hope the re-wire was worth the trouble as I doubt the supplied wires are that bad to start with). Hugo's mounting base is a must judging by all the comments and I'd probably look for a hard-wood arm-board, as well as a suitable headshell, which seems essential for best performance of these types of tonearm.
