The R200 should be an excellent match, since the bias can now be repaired should it fail and the height and weight of the arm is about right. Mine ran the Decca Microscanner with pod, a lead weight and an ancestor of the Sumiko shell with no difficulty.
Apart from the simplicity, the R200 is actually a very fine tonearm in my opinion. I added a strip of thick sleeving to the lateral balance weight as Rega did for the Planar 3 versions of this arm (which had slightly better adjusted horizontal bearings, together with a Cardas male socket so the arm could take alternative exit cables (my inner wires are original).
