If you get lots of peak, it sounds like bass all blend into a monotone sound, or sounds really boomy and shouty?
I'm fuckoff.
Both really, lack of bass definition & a lot of boom rather than being able to make out each individual note. As you say, it's monotonous
Bests, Mark
I'm fuckoff.
Is this kind of DSP what people try to achieve with room treatments, just another angle of attack?
Yes, but I'd suggest that this is going to be more vastly more accurate in the bass end. Remember they can't correct above about 144Hz
As I suggested in the PM I sent you, it's best to use as much of that frequency range up to 144Hz as possible. That way you'll benefit the most, also why I'd use small stand mount speakers (with a sub or subs operating to as high a frequency as possible) if I hadn't ever gone active
Bests, Mark
I am not doubting anything that anyone has posted, least of all Mark RM but I see this as a 'use once and store in the loft until you rearrange or change something in your layout' sort of product and how often do most of us do that?
As such, given it's apparent ease of portability, could there not be a case for a group of forum members, or the forum as a whole, buying one for shared use amongst quailfying members?
Any thoughts?
Dave.
DaveK.
My System:
Room correction devices have to be installed in the system all the time, I imagine the Duo Core is the same?
Keith.
Cessaro Horn Acoutics,David Wright ,Mola-Mola , Weiss MAN301,Dynavector XV1- Manger Loudspeakers Grimm Audio LS1,worlds best sounding loudspeaker.
Mini DSP digital signal processing.
www.puriteaudio.co.uk
I'm fuckoff.
Yeah, it needs to be on all of the time to work, like any other part of your system.
Correct connected and left in the system.
I have stock arriving Friday available for instant shipping.
Bests, Mark
Fantastic! A true believer (and with good reason).
Happy to do free shipping on these.
