Ok I have the TD124 out of the box and on the table its very clean some paint damage to the edge of the arm board, and slight bubbling under the platter.
The motor mount bushes look pretty shot so they are on the order list.
The main bearing spindle looks very clean as does the bottom of the bearing housing.
The only problem I have found so far is that the fine speed adjust link bar is slipping when the adjustment is turned.
It looks like the spring is stuck so no pressure is being applied to the link bar.
Does anyone know how this mechanism should work?
Source: Thorens TD124 Rega RB300, Sumiko bluepoint No2., Cambridge Audio D500 Special Edition CDP, Squeeze box Touch, PC with Trends Audio USB Audio DAC UD-10 Amplification: Croft Micro 25 basic pre, Leak Stereo 20, Trends Audio Class T TA-10, Fisher X100-A Speakers:Impulse H6 Interconnects: Handmade silver and TNT audio CAT5 speaker cables
