Here's the new 20 amp diode bridges with their +/- wiring. That's an AA battery for scale, I don't have much fear these will overheat....
I'm Nobody.
I Thought you would have gone for bridge rectifiers made from individual Diodes!
Andre at 20 amps (US) you need the thermal mass to bolt down to dissipate the heat. I was tempted by the IXYS silicon bridges, but at £100 each, nah......
I'm Nobody.
I just thought that's what serious Hi-Fi guys did automatically but i understand.. Yeh ive seen those IXYS Packages i think they are German..
Eeee, sithi tha doin a reyt good job o that sunshine! - spot on!
Tannoyista.com - Audio Equipment Reviews
I'm Nobody.
Aye reyt goowd amps dem towd Krells
460 miles of driving
105 hours of unscrewing, removing, twisting, cutting, scrubbing, wiping, rubbing, spraying, wire brushing, polishing, screwing and soldering.
16 crimp fittings
12 brass screws
4 metres of solder
3 foot of solder wick
6 pints of PSU caps
3 metres of wire
36 small signal caps
50cm of heatshrink
2 tins of isopropyl cleaner
1 tin of flex remover
10 grazed knuckles
1 squashed toe
1 arse flapping moment
and it's job done...
I'm Deleted.
Yeah, nice job, I thought it sounded jolly good .
Account Deleted
Right then no more after this I promise.
Dirty vent slots, back/centre and RHS where the PSu cap has let loose and the electrolytic has carbonized the anodizing.
With the help of a cordless drill, some bamboo kebab skewers and a bottle of T-cut (fine) I was able to polish out all the carbon without damaging the anodizing.
Now it's done...
