I like a challenge!
Actually you can get a fairly good idea without recording anything by using a 3~4" length of drinking straw taped to the headshell which gives an amplified view of the wobble and then noting how far into the track you get when it happens....I need to get out more LOL!
The effective mass calculator in VE is good enough, provided you enter in the required information as accurately as you can: effective mass of the arm (including the headshell); mass of the cartridge; mass of the cartridge fixings, and the dynamic compliance of the cartridge at ~10Hz. If the result lays within the range 8 - 15Hz, then one should not have a problem.
Ideally testing the combination using a swept-tone test track, or individual test-tone tracks, covering the range 5 - 20Hz is ideal, but in my experience (of over forty years), the calculated value is usually sufficiently good to know if there might be a problem.
I finally stumbled on this:
http://audiosensibility.com/blog/faq...-750-tonearms/
Hope this helps,
Jim
Seems that due to the aluminum connector, the 750L 12" is lower in mass than the 750D with a brass connector. Interesting!
Music is what it's all about, but I sure like the way my gear makes it come to life! My gear >
http://theartofsound.net/forum/album.php?albumid=123
I'm Bastien.
