Results 1 to 10 of 16
Thread: Jelco effective mass
    I'm arecurringnightmare.
    Default Jelco effective mass
    Anyone here know what the Effective mass of the Jelco SA -750db is? I can't seem to find a reliable source.
    Also am i right in thinking the Headshell mass is 12Gr?
    Thanks in advance.
    Charles
    Acer Laptop/Foobar/WASAPI/S/PDIF/DacMagic/Mini T/Mission 754
    I'm Juha.
    I have this info, cannot remember where I got it:
    Effective mass 20gr for SA-750D 9"
    Effective mass 26gr for SA-750L 12"
    Effective mass 18gr for SA-250ST 9"
    My Gear
    Source components:
    Garrard 401 in a solid birch plywood plinth / Trans-Fi Terminator T3Pro / ESCo modified Denon DL-103
    Pioneer TX-9800 tuner
    Amplification:
    Art Audio Diavolo and Conductor, Pair of XTZ Sub Amp 1's, Nick G 'Dual Phono' phono stage
    Loudspeakers:
    Bastanis Mandala Atlas with 15" sealed woofers
    Cables:
    Analysis Plus: Big Silver Oval speaker cables and Silver Oval-in interconnects, Mark Grant DSP 2.5 Dual Screened power cables
    Record cleaning
    Nitty Gritty 1.5Fi MK II
    I'm Buffet-blower.
    Quote Originally Posted by selfaddict View Post
    I see there was an answer from the Head of Sales at Jelco (in Japan I think) to a letter written by someone on VE - he stated it was 20g but didn't say if it was with or without headshell. I'd presume without, seeing as the SA250T is would be very close at its own 18g eff mass (which is fixed shell).
    The info does seem somewhat elusive though - been searching for a while myself.
    Richard.
    Round & round bits: LP12/Cirkus/Kore/Herc II/Roksan Nima/Hana EL
    Megabits: MacBook/Sony CDP-X303ES/TEAC UD-H01 dac
    Making it louder bits: Phonostage: Dynavector P75 Amp: Cyrus 8vs/PSX-R Speakers: Royd Sintra II
    Connecting it together bits i/c's: Flashback Premier. Speaker cables: Van Damme Hifi
    Thank you. I had Emailed Jelco direct for the answer, if i get a reply i'll post here, just for future reference.
    Does seem strange them not showing the Effective mass in their Spec sheet tho. Surely its one of the most important aspects for Cartridge matching.
    Charles
    I'm Buffet-blower.
    Quote Originally Posted by Artifolk View Post
    Those were exactly my thoughts too.
    Richard.
    I'm Alex.
    Thanks in advance.
    Charles,
    The standard headshell is a tiny bit under 12g.
    The arm's effective mass is 20g, as shown in this email from Jelco below (posted to Vinyl Engine). I can't imagine that the effective mass is quoted without the headshell - that would be 32g, and most modern medium/low-ish compliance cartridges would be rendered incompatible.
    Posted Mon, 01/25/2010 - 20:45 by Alfredo56
    I asked the news of the effective mass Jelco arm SA 750-D, the answer:
    Dear Bisogno,
    Thank you for your inquiry for SA-750D tonearm.
    Effective mass is 20gr.
    Damping oil is 500cps silicone oil.
    Best regards.
    Haruo Uchida/sales manager.
    Kind regards,
    Alex
    Technics SL1210| Jelco SA-750| Benz Micro ACE SM MC| Squeezebox Touch/MCRU linear PSU | Cambridge Audio 851C | High Resolution Music Streamer II+ / Linestreamer+ | Raspberry Pi 2/IQ-Audio DAC+ / Max2Play | Conrad-Johnson ET3 Control Amplifier| Conrad-Johnson LP125sa KT120 Power Amplifier| Avalon NP Evo 2.0 Speakers| Cardas Audio Quadlink-5C Speaker Cables and Interconnects| Finite Elemente Pagode Signature E-14 equipment support
    Michell Orbe with Moerch DP-6 Gold Precision & London Jubilee / Radford WS1 > Woodside DVAC-18 > Radford SC25 Renaissance Series / CAT SL-1 > Radford MA50 Renaissance Series / Audion Golden Night 300B > Audio Nirvana 15" Classic Alnico with Tannoy ST200.
    Hi Andrew,
    The answer is that the Jelco SA-750D (the most commonly sold model) has an effective mass of just under 14g, which of course can be tailored (mass decreased or increased) by fitting a lighter or heavier headshell to the tonearm.
    Ignore other info in that respect, given earlier on the thread, as it is bogus.
    The SA-750D is thus best suited for use with low to medium compliance MC cartridges. The Denon DL-103, for example, is a really good match.
    http://www.thestainedglasscompany.com
    "A man is a success if he gets up in the morning and gets to bed at night, and in between he does what he wants to do" -- Milan Kundera.
    BE HAPPY EVERYDAY!
    Hi Marco! Thanks for reply.
    I've also contacted with Jelco Ichikawa support and asked them to confirm this information.
    They confirmed it:
    Thank you for your inquiry for SA-750L(12") effective mass.
    Details as follows.
    Effective mass is 10.96gr without cartridge.
    Effective mass is 18.56gr with 6.5gr cartridge.
    Best regards,
    Therefore, previous info about the 26 grams of Jelco SA-750L is absolutely incorrect.
    Regards, Andrew.
    I'm Neal.
    There is an effective mass calculator over on VE, you need the resonance frequency given by a test record, the cartridge compliance, cartridge and fastener mass. The resonance frequency needs to be quite accurate though, I ended up recording the resonance track whilst timing it from the start to the point at which the arm went unstable then analyzing the track in Audacity and noting the frequency at the timing point.
