Garrard 301 Plinth
Hi,
I wonder if any one can help me? I'm in the process of designing a slate plinth for a 301. To start with this is going to be a very simple plinth with just the cut-out for the deck and a hole for a rega arm mount.
I have a couple questions I have some CAD drawings for the 301 with the arm radius's on, but is there a position along the radius which is preferable to position the arm?
Also as I'm planning on mounting the arm straight onto the plinth its self with out an arm board will I need to fit a spacer under the arm to raise it to the correct height?
If I can work out how to PDF the file and upload it I will.
Thanks
Source: Thorens TD124 Rega RB300, Sumiko bluepoint No2., Cambridge Audio D500 Special Edition CDP, Squeeze box Touch, PC with Trends Audio USB Audio DAC UD-10 Amplification: Croft Micro 25 basic pre, Leak Stereo 20, Trends Audio Class T TA-10, Fisher X100-A Speakers:Impulse H6 Interconnects: Handmade silver and TNT audio CAT5 speaker cables
