I have sold a few of these but do not advertise them as they take sooooo long to assemble but as there seems to be a renewed interest in silver here it is. The difference between mine and many other silver cables is the terminations (which I think are as important as the cable if not more so).
This mains lead uses an IeGo pure silver IEC connector, cryo treated and manufactured to very tight tolerances (hence the tight fit into the mating IEC inlet), the silver comes from melted down silver coins and I have heard this connector in action, it is quite superb.
The wire I use is imported from Japan, 5N pure silver which I think is about the best available, it is expensive but I have tried many others and this sounds the best, I use 2 x 1.5mm for live, 2 x 1.5mm for neutral and 1.5mm OFC copper for earth.
As there is currently no pure silver mains plug available (I am working on it) I have used my own reference mains plug which is 15 microns silver plated by a company with 50 years experience in this field. The plug is fitted with my favourite fuse Hi-Fi Tuning UK Gold with pure silver fuse wire.
1 metre long as standard, longer lengths made to order, £395.00 delivered.
Also available with silver plated Schuko plug or USA Nema plug for small extra charge. PM or e-mail to order or discuss your requirements. Thanks
