This phono stage has recently replaced a Cambridge Audio 540p in my modest system (see kit list in my signature for details). Having now lived with it for several days, I thought I'd share my opinions here.
These phono stages are made in Suffolk and sold on eBay by Angle Audio (eBay username: “949person”). Several standard options are available and, as each unit is made individually, tailoring input sensitivity, gain and loading to your specific cartridge during manufacture may be possible. Delivery was quick - I ordered mine on a Sunday afternoon and it was delivered on Thursday.
My phono stage is the “Audiophile Phono Preamp with 'virtual battery'” moving magnet version (1.25mV to 5mV input sensitvity, 47KOhm loading) which currently sells for £145 including signed-for delivery in the UK. A moving coil version (0.15mV to 0.5mV, 470Ohm) is also available at the same price. Other options include a version without the 'virtual battery' (for £25 less) or with switchable MM and MC inputs (£25 more).
The unit appears to be well constructed in a sturdy metal case. Rear panel connections are as expected – a pair of phono sockets for the input and a pair for connection to your amplifier. A substantial earth terminal and a DC power socket complete the picture. The front panel has a single toggle switch and pair of LEDs. A large and heavy 15v plug-top mains power supply is provided – so large that I needed to shave a couple of millimetres of plastic off the side of my turntable mains plug to allow them to fit into adjacent mains sockets.
Operation is straight-forward. With the toggle switch in the “up” position, the phono stage is “off” (left-hand LED not illuminated) and the internal battery is set to either “fast charge” (indicated by the right-hand (green) LED flashing), or “trickle charge” (right-hand LED steady green) depending upon the charge currently held by the battery. Flicking the switch “down” turns on the unit (left-hand LED glows red) and the battery goes to “trickle charge” mode. I could detect no hum or other unwanted noise from the speakers nor from the unit or its power supply when switched on.
First LP spun was Everything But The Girl's “Walking Wounded” . This album has lots of very low, tight bass and it was evident from the fist few notes that this bass sounded deeper and more tuneful than via the Cambridge Audio stage. This bass quality and extension was also very evident on the next record – a live version of Kraftwerk's “Radioactivity” (Promo-only 12” single) which sounded fantastic.
Next up was the Cowboy Junkies “The Trinity Session”. Soundstage width and depth here were excellent and the treble sounded clean and extended without any signs of harshness nor undue emphasis of sibilance (the track “Sweet Jane” I have found to be a good test of this). Good resolution of detail was in evidence - the noises from the heater in the church were very clearly audible.
Listening continued throughout the day with a bunch of LPs all recorded in 1972 – Bowie's “Ziggy Stardust”, Jethro Tull's “Thick as a Brick”, ELP's “Trilogy” and Steely Dan's “Can't Buy A Thrill”. Each one had my toes tapping and I found it hard to listen critically as I was enjoying the music too much – always a good sign!
One operational quirk should be mentioned here. Although the battery is held in “trickle charge” mode when the unit is switched on, it is still possible to flatten the battery after about 6 hours continuous play. If this happens, the only option is to switch the phono stage off to allow the battery to fast charge. This is something I can live with, but I could see this being a consideration for some people.
So in conclusion, I find this phono stage to be a vast improvement on the Cambridge Audio one with an excellent, well-balanced sound throughout and is great value for £145.
