Hi
Great forum, been lurking a bit but I now have a question, hope you can help!
I just managed to break one of the loading resistors on my tonearm cable (I solder it across the signal/ground inside the phono jack, which I read somewhere is the same as putting it in the preamp, makes it easier to change values and I'm too lazy to put them inside the preamp!). They are 1k ohm resistors that came with my Audio Research SP9 preamp. The 100 ohm ones don't sound as good so looks like I need to find some replacement resistors.
I'm all for 'audiophile grade' components if they make a difference but not snake oil hifi BS
Does anyone have nave recommendations (UK preferably)?
ta
Simon
