The Highphonic SUT will arrive tuesday. Unfortunately the customs needed a big part of money also
But that is allways the risk with buying outside the "EU".
I'm Paul.
Yup, it was the same for me when I bought my Denon DL-103GL and AU-310 SUT from him - but when you consider just how good some of this gear sounds/performs, compared with a lot of 'mainstream' stuff today, even when factoring in the import charges, it's still a bargain!
Anyway, drop us a not when it arrives and what your thoughts are
I'm Paul.
The Highphonic SUT is in it looks really nice. The sound is really really good. The rothwell headamp is unfortunately no match.
Better instrumental separation. More dynamic also. The stage is more deep.
Marco thanks for your tip
Sent from my VOG-L29 using Tapatalk
That was pretty quick, Paul!
Nice one, though. So glad it worked out well, as it's always a risk giving (fairly expensive) reccos to someone who's system you've never heard... I'm not surprised though that the Highphonic sounds good, as it was designed to match the Pro, so you should have real synergy at work, which is always key, IME, to getting a great sound from vinyl!
Enjoy - and yes it does look good!
I'm Paul.
I made a deal for fast shipping i am very impatient
Lol - I'm the same! My stuff took ages to get through customs, though [nearly 3 weeks!]
I'm Paul.
I am still enjoying my SUT it is an magical combination. As discussed on another forum it is a good as the weakest link. Which was my headamp before.
I'm Paul.
I like my DL103Pro very much. I have an Benz Micro Glider L2 and AT33PTGII both do not give me the Joy that i have with my Denon. I am allergic for IGD they both have it and they are professionally installed.
What would be an nice upgrade of the Denon without the headache from AT and BM?
Hi Paul,
How are you? Hope you're well and staying safe!
Glad you're enjoying your 103 Pro and Highphonic SUT. It should be a very good and musically satisfying combination. In terms of IGD, it should be minimal (virtually inaudible) with ANY cartridge (and arm) that's been *fastidiously* well set-up!
However, you'll always get a little more with a conical tip, than with ellipticals or fine-lines, simply because of the nature of their stylus profiles, although with everything optimised the difference, audibly, should be negligible.
As for upgrading from the Denon, in the way you describe, firstly you must understand that you won't be able to achieve such, universally, as the 103's unique talents, musically, simply won't be automatically usurped by another cartridge, arguably more accurate, by dint of having a superior stylus - there are *always* tradeoffs!
However, if you wish to retain as much of the Denon's sound (musicality) as possible, but add a little more polish and finesse, my recommendation would be to consider cartridges from Phasemation and Miyajima (PP-300 and Takumi, respectively), as shown here and available from the website of one of our traders:
https://ammonite-audio.co.uk/product...ble-cartridge/
Hugo's a top bloke and great guy to deal with, and whom I've no doubt will help you achieve your aim. Cartridges from both of said manufacturers are voiced to sound 'musical', not clinical or 'artificially hi-fi', like the products of many of today's manufacturers, so there'll be no such 'headache' to worry about!
Hope that helps
I'm Paul.
Hi Marco,
I am well including family. Thanks. What i find out is that i am very prone to distortion of any kind. One time during a listening session with my speakers i heard an distortion no one else could hear. Then after an sound sweap we found out that the magnets of my planar speakers was coroding and where touching the foil. Also i can hear the buzzing of the adapters of handphones. So with cartridges i am prone to distortion too. My AT and Benz Micro are more prone to IGD then my Denon. The Benz Micro is installed by an professional wo did the retipping of the Benz Micro. Also changing the anti skating made it less prone but is still there. Do you think the 2 cartridges mentioned are less prone to IGD?
