Does anyone have any advice on how to convert .m2ts files to AVCHD files ?
Also, are there any free converters that do the job properly, and without causing major heartache or headaches ?
Chris
Common sense isn't anymore!
never come across those formats myself but then again i don't have much on bluray, what exactly are you tring to do chris
The only video converter I have ever had any joy with is handbrake ...
I'm no expert but it would be worth a look
I recently bought a Panasonic Viera TV, and amongst things it will do is play video from SD cards or USB sticks.
I have a file in m2ts. format, and I need to convert it to another format for the tv to be able to read it.
So it's start of the learning curve time for me
Chris
your tv should be able to play some avi formats so try WinAvi and see how you get on.
Chris,
my LG tv is similar in what it does and I tried this to get m2ts files to play.
rename the movie file....ts instead of m2ts.
ie. filename.m2ts becomes filename.ts
This works with my LG plasma.
alternatively, try this next:
http://www.videohelp.com/tools/multiAVCHD
didn't work? Try this.
http://www.videohelp.com/tools/AVCHDCoder
hope this helps,
Gaz.
AC POWER
AMPS
SPEAKERS
Wharfedale Evo 4.4
DAC
TURNTABLE
PHONOSTAGE
DIGITAL
MUSIC PLAYBACK
Ipad Roon Remote.
SPEAKER CABLES
INTERCONNECTS
Thanks Gaz.
Unfortunately I deleted the files in question, so I can't give it a go
Chris
shame...
ah well.
one of these options SHOULD work though if you ever come across another m2ts file.
AC POWER
AMPS
SPEAKERS
Wharfedale Evo 4.4
DAC
TURNTABLE
PHONOSTAGE
DIGITAL
MUSIC PLAYBACK
Ipad Roon Remote.
SPEAKER CABLES
INTERCONNECTS
