Results 1 to 10 of 10
Thread: Caiman as pre with valves
    I'm Jim.
    Default Caiman as pre with valves
    Hi
    Anyone using a Caiman as pre with valve power amp or mono's?.
    At present I'm using a Caiman (not as pre) into a Yaqin MS-6V6, sounds great into Infinity reference 60's but I suspect more power would be worthwhile.
    Also if there are any MS-6V6 owners out there I'm looking for info regarding changing valves and biasing, I have read that the MS-6V6 can be run as a pre or power but have no idea how to achieve this,
    Regards
    Jim
    Jim.
    I'm Jim.
    Hi
    Thought I would give this a bump in case anyone missed it first time round, I would be grateful for any help on the subject.
    Regards
    Jim
    Jim.
    I'm Ross.
    Pretty sure Gazman is using a Gatored Caiman with Bantam mono's. Or possibly a Mini-T :¬)
    Speakers: Kii THREE
    Headphones: Lumin A1 > Simaudio Moon 600i > Abyss AB-1266
    I'm Gary.
    Quote Originally Posted by Yoga View Post
    Not yet...but I will be.
    Currently using my Gator'd Caiman with a "loaner" T-Amp wired up with spit and chewing gum, but sounding pretty great.
    Bantam Mono's next purchase to upgrade the amp side of things.
    Not used the Caiman as a pre, but others have and I've read on here and elsewhere that you'd need to spend serious SERIOUS money to comfortably better it as a preamp.
    No reason why it wont work as well with valves, but I'm sure others will pitch up with their direct experience.
    Gaz.
    AC POWER
    AMPS
    SPEAKERS
    Wharfedale Evo 4.4
    DAC
    TURNTABLE
    PHONOSTAGE
    DIGITAL
    MUSIC PLAYBACK
    Ipad Roon Remote.
    SPEAKER CABLES
    INTERCONNECTS
    I'm AMusicFanNotAnAudiophile.
    Gaz.
    Not necessarily the case.
    I was pretty happy using the Caiman as a pre in my setup.
    My amplifier can be split into two section, pre and power, so I'd just split up the two sections and plugged the Caiman directly into the power amp.
    When I change configurations around I'll often revisit a previous setup just to see whether what I'm hearing actually is an improvement.
    I recently went back to some interconnects I'd previously used, and also tried the Caiman with fixed output back into the line in on the preamp.
    The improvements with each reversion were not subtle.
    The amplifier ?
    A lowly NAD C320BEE.
    Chris
    Common sense isn't anymore!
    I'm Jan.
    I am using my Caiman as a pre-amp; saw no reason to add yet another link in the soundchain, so it replaced my old Carver pre-amp.
    Also connected my TV and Toshiba to the Caiman
    Still no valves, but why not
    Jan.
    Main: Touch -> Beresford Caiman II -> Carver A-500x -> B&W 704
    Office: Duet (Audiocom)
    -> Luxman L-210 -> Stax SR84 Pro
    -> Beresford Bushmaster -> Superlux HD668B
    Server: A8-5500, 4 GB, SSD + 2*1 TB, Win8 w. SBS 7.9 (SQLite w. High Mem)
    Tied together by D-Link DIR-655 + DGS-1008D
    I'm Gary.
    The amplifier ?
    Expectation Bias Chris?
    Good call to always go back and check though....
    When you tried the Caiman fixed into the Line in on the Nad, was it being used as an integrated or was there a poweramp somewhere?
    ta.
    AC POWER
    AMPS
    SPEAKERS
    Wharfedale Evo 4.4
    DAC
    TURNTABLE
    PHONOSTAGE
    DIGITAL
    MUSIC PLAYBACK
    Ipad Roon Remote.
    SPEAKER CABLES
    INTERCONNECTS
    ta.
    Using the Caiman as a preamp brought a slightly different take on things, one that I initially found seductive.
    Retracing my steps brought life, drive and vitality back to the sound.
    The NAD is now back to it's original integrated configuration
    Chris
    I'm Imjustsurviving.
    I have used my caiman as a pre amp on a valve amps just to try, it worked ok but found the volume pot can be bettered, you still need something to control the output volume be it a pre amp or a cd player with its own output volume control, perhaps a simple passive pre amp in line
    Jon
    A person who never made a mistake never tried anything new.
    Set up
    Lafayette el84 power amp , Audio note M1 pre , Tannoy Sterlings, Garrard 301 , SME 3012 , puresound P10, Ortofon SPU, Cambridge CXN streamer
    Micro mega Duo 3 cd transport ,
    I'm Jim.
    Hi
    Thanks for your replies guys, I will try my Caiman with valves when I can blag some for a demo. In the mean time I think I will Gatorize the Caiman and add a better power supply.
    Regards
    Jim
    Jim.
