Results 1 to 5 of 5
Thread: Technics 12XX: Voltage and current requirements?
    Default Technics 12XX: Voltage and current requirements?
    OK guys, I'll need some information here... What are the voltage and current requirements of the SL-12XX Mk2? A friend of mine who is an electrician wants to explore the option of making an external PSU for his own and, if it works out well, we might end up fitting something like that to mine (otherwise, I'll consider other options, such as a Timestep or a customized Trichord Never-Connected or a Paul Hynes).
    My system:
    1. Technics SL-1210Mk2 (stock... For now)/Ortofon 2M Red cartridge/Musical Fidelity V-LPS preamp
    2. Philips DVP-9000S Cineos SACD/DVD player
    3. Audio Analogue Primo Settanta integrated amplifier
    4. Klipsch RB-25 loudspeakers
    5. Monster Cable Interlink 250 interconnects
    6. Roister (that's a Greek loudspeaker company) OFC speaker cables
    7. Atacama Nexus speaker stands
    Konstantinos.
    Hi Konstantinos
    Can i suggest you try removing the onboard psu and placing (safely) in a separate case as a starting point ! You may be surprised at this
    Chris
    Well yes, but, if memory still serves me correctly, I asked a certain question, not if I can take the existing PSU out of the deck's chassis.
    My system:
    Konstantinos.
    Yes indeed , well Paul Hynes is probably your man for this question
    Chris
    I'm John.
    Quote Originally Posted by Epicurus View Post
    The voltage requirements are easily obtained from the schematic (available on the VE forum). I made some current measurements myself: http://theartofsound.net/forum/showp...44&postcount=7
