Looking at a photo of the drivers, they look interesting. Are they sandwich type speakers?
I know the 15" is & the lower mid, the upper mid & tweeter are the same as used in certain Wharfedale speakers
Bests, Mark
i'm sure there was a bigger brother with ribbon tweeters
Edit oh yes it was the 3090's, just found you in a thread on Pink fish Adam talking about them
Jon
A person who never made a mistake never tried anything new.
Set up
Lafayette el84 power amp , Audio note M1 pre , Tannoy Sterlings, Garrard 301 , SME 3012 , puresound P10, Ortofon SPU, Cambridge CXN streamer
Micro mega Duo 3 cd transport ,
I'm Nobody.
'2075' are from the Leak era i like to forget about tbh
Adam's sounded lovely at Scalford.
I THINK the 3090s are the same size; would you like me to measure mine?
I have them either side of a 50 inch Kuro, in the lower-split level part of my living space.
Nice relaxed sound, and the bass WILL move air, but only at unsocial volumes! That's SOUND volumes....though I guess AIR volumes applicable too.
And, yes, Sandwich construction bass units.(and mid).
Luckily they seem to last (I have a pair of 15 ohm 'normal' Sandwiches too.) The surround is doped fabric on those, rubber on the 15 inchers.
The mids were an early example of computer designed speakers. There are spiral lines of holes to break up resonance.
The (huge) cross-over is bigger on the 3090s as well, i believe. Mine have been re-capped with Solens (?)
I am full of admiration for the dedication that it takes to shift those all the way to Scalford (AND turntables etc as well!)
I'd post a pic, but have no site to use. Can email them.
Chris.
