Hi folks , im not convinced that mains cables make a difference to sound quality, but think my system deserves better than standard kettle leads , also
having three fuses into my amplifiers seems mad , it would be ideal if you could get a mains plug with no fuse , and only the correct rating fuse in the
components , ive been looking at the viborg ve80
https://www.hifi-amplifiers.com/en/v...ts-p-5396.html
fairly cheap and there plugs are
copper , has anyone used there gear , im not interested in using standard plugs because of the fuse , any bargains out there im missing . phil.
