Just a quick update to say the DS2 usb phono stage is very good and ripping vinyl with it and vinyl studio pro is a doddle. also have added a digione case to my rpi; the ali one and its quite nicely made if a bit of a pig to fit with no instructions(hope you are reading Allo)
https://uploads.tapatalk-cdn.com/201...60ac6b1d55.jpghttps://uploads.tapatalk-cdn.com/201...663334ec36.jpg
I might add the Vena is starting to come more on song now after me doing some burning in etc though both the coax, optical and usb sections..just left the power amps off while it did it thing
Got another of these record display cases today.
A black one this time
Easy to build and strong. https://uploads.tapatalk-cdn.com/201...e3f54d354c.jpg
Been using one of these with my headphone amp.
It does what it says.. Excellent upgrade https://uploads.tapatalk-cdn.com/201...dec2e03d6c.jpg
and the little devil in circuit
Second tophttps://uploads.tapatalk-cdn.com/201...0b70fee9f8.jpg
Quite impressed with this actually
Got a link to this Grant ?
Fairly recently I picked up another set of wireless cans. Mainly to use with my phone as it does ldac which is fairly high bit rate.
Decided the second top in Sony range the n900 was the one, and in green was cheapest so went for them.
https://uploads.tapatalk-cdn.com/201...606839ff0c.jpg
was quite windy out back today so set the noise reduction to wind and it works well.. vast reduction in wind;)
For the money these are very good if you have a sony phone that does ldac especially. The green colour is only very slight tbh so you dont look like a prick:eyebrows:
Sound quality, although not at the level of the nuraphones, even at a lower bit rate, is extremely good and the signal is good too. boogie factor 9, and extremely comfortable too
Slight alteration to the set up. Out got the bt3 actives and the xs dac.
Less cluttered as long as you don't look down the backhttps://uploads.tapatalk-cdn.com/201...5e08fe7999.jpg
