I'm having a new sound system installed in the Brabster, some of which has been recycled from my old car. The biggest difference will be the dedicated mono amp, to drive the sub, which should help produce some PROPA BANGIN' CHOONZ!:D
Front End:
Kenwood DNN6250DAB head unit:
https://imagizer.imageshack.com/v2/1...923/sD9DdR.png
Full spec here: https://www.kenwood-electronics.co.u...av/DNN6250DAB/
Amps:
JBL GTO-804EZ (80W) - 4 Channel Amplifier:
https://imagizer.imageshack.com/v2/1...921/TGv5m2.jpg
Full spec here: http://www.caraudiodirect.co.uk/jbl-...nnel-amplifier
JBL Club 5501 (550W) high-performance mono amplifier (for sub):
https://imagizer.imageshack.com/v2/1...924/UnHqXX.jpg
Full spec here: https://uk.jbl.com/car-amplifiers/CL...urrent#start=1
Speakers:
JBL GTO 609C front-door speakers with matching crossovers and tweeters:
http://imagizer.imageshack.us/v2/xq90/909/Omv5wP.jpg
Full details here: https://uk.jbl.com/car-audio-systems...SAAEgKnLfD_BwE
JBL GTO 529 rear-door speakers:
https://imagizer.imageshack.com/v2/1...921/byHCNI.jpg
JBL 1214BR subwoofer:
https://imagizer.imageshack.com/v2/1...924/pd2MHs.jpg
Full spec and review here: https://www.adamrayner.net/jbl-gto1214br/
Cables:
Klotz MC5000/Neutrik Pro-Fi interconnects, 3 x 5m pairs:
https://imagizer.imageshack.com/v2/1...924/MKDa25.jpg
Full details here: https://www.studiocare.com/klotz-neu...onnectors.html
Klotz SCH-4040 speaker cable (20 metres in total):
https://imagizer.imageshack.com/v2/1...921/nEdbli.jpg
A small amount of Dynamat, sound deadening material, will be applied to the door panels and subwoofer housing. Just enough to dampen the cabin and boot, without adding much weight.
The 'boot build', housing the amps, and sub [after being externalised from its existing ported box], will look similar to what's shown below (now turned into a sealed enclosure), and recessed into the boot area, in order to ensure that space for suitcases, etc, isn't compromised. My own install will have (switchable on/off) 'Ice Blue' LEDs instead, to match the 'Brabus' illuminated door sills on the car, like this:
https://imagizer.imageshack.com/v2/xq90/924/2rOuOJ.jpg
All else will be black, not green, as is shown in the pic:
https://imagizer.imageshack.com/v2/6...922/8eYA2f.png
https://imagizer.imageshack.com/v2/6...924/48Iqse.png
https://imagizer.imageshack.com/v2/6...922/SKyajQ.png
Should be fun! Pics of the full install, from 'work in progress' stage until final build, will be sent to me from my installer and posted in due course:cool:
