ATC SCM11 MKII 2-way Standmount Speakers - Multi Award Winning
ATC SCM11 MKII 2-way Standmount Speakers Multi Award Winning
Immaculate ATC SCM11 speakers, very little use complete with original boxes.
The ATC SCM11 is a full size monitor offering a high-end full musical sound.
Capable of musical peaks of 108db and coming from a heritage of musical loudspeakers, the ATC SCM11 is something you must take a listen to.
The ATC SCM11 employs all the specialist ’soft dome’ technology found in the reference systems we build for the recording industry. It is this design feature among others that contribute to the wide bandwidth and exceptional dynamic range of this outstanding loudspeaker.
In real wood veneers, the ATC SCM11 offers all the unique sonic advantages for which ATC speakers are valued the world over.
Drivers: HF 25mm Neodymium, Mid/LF 150mm
Matched Response: ±0.5dB
Frequency Response (-6dB): 56Hz-22kHz
Dispersion: ±80° Coherent Horizontal, ±10° Coherent Vertical
Sensitivity: 85dB @ 1W @ 1metre
Max SPL: 108dB
Recommended Power Amplifier: 75 to 300 Watts
Nominal Impedance: 8 Ohm
Crossover Frequency: 2.2kHz
Connectors : Binding Posts/4mm Plugs, bi-wire
Cabinet Dimensions (HxWxD): 381x232x236mm
Weight: 10.9kg
£925
https://live.staticflickr.com/65535/...51f1aea9_z.jpgP1000782 by Martin, on Flickr
https://live.staticflickr.com/65535/...51e821fd_z.jpgP1000783 by Martin, on Flickr
https://live.staticflickr.com/65535/...8efb1cf0_z.jpgP1000784 by Martin, on Flickr
https://live.staticflickr.com/65535/...b0035b7c_z.jpgP1000785 by Martin, on Flickr
https://live.staticflickr.com/65535/...af488bb1_z.jpgP1000786 by Martin, on Flickr
https://live.staticflickr.com/65535/...2240a835_z.jpgP1000787 by Martin, on Flickr
