I noticed this https://www.rotel.com/en-gb/product/t11
I don't know the kit - it's probably fine.
However the page says "Engineered with care".
Am I the only one who is immediately hit with the cover not being lined up in a regular fashion?
I noticed too, it would bug me.
Gary
I don't know what you're looking at, but I can't see anything amiss.
looks ok to me. the black plastic inner cover is squint and the display doesnt look central in the vertical but it could be optical.
And the wires aren't straight :D.
Same as me even if they are usually like that they could adjust it for the photo. Mind you at least they're honest.
Re the wires is definitely not a Croft!
They are talking about the inside casing labelled "Caution - Do Not Remove" etc...
...maybe they should have put that label on the outer casing - to stop people seeing how it clearly is not engineered with care.
I see that now. My screen is too small, it just looks like a black blob unless I get really close up.
I wonder though if the lid would push it back down and square one it was back on?
