I concur, as that's also been my experience, and not strange at all when you understand the valid reasons why!;)
Newest/latest isn't necessarily best, with regards to many things in life, not just hi-fi......
...and also run a fully-regulated linear PSU, for the hard-drives supplying music files to the Pi (electrically/mains-generated noise is the biggest enemy of any file-based system, so it should be addressed and minimised *wherever* possible in the replay chain).
Cheapo SMPS units fatally hobble streaming set-ups like you wouldn't imagine. Quite simply, they have no place whatsoever, ANYWHERE, in a high-end audio system!!
Doing the above (in conjunction with installing Supra CAT 8 patch cable, see here: http://www.jenving.com/products/view...tch-1001908589 throughout, instead of bog-standard stuff from Maplins) resulted in one of the biggest upgrades I've applied to my streaming set up!:)
I have a Digione feeding the DAC in my Perreaux 250i (ES9038Pro) and it's stunningly good. I must have tried 7 or 8 HAT Dacs before settling on the Digione. The Digione is fitted to an RPi with screen in an Audiophonics RaspTouch case :
https://www.audiophonics.fr/26577-la...me-control.jpg
and the music is stored on an SSD connected to an RPi running Logitech LMS. Both have their own linear supplies.
Hi Jim,
Yes, Mike and i made a bit of a deal for the DAC for a bit of cable for his Mission arm. Suits us both with minimal cost!
I am immensely impressed with the Allo DAC and Mike suggests his Piano DAC is better so i may try that before i send the rest back lol. Might have to make another deal :lol:
In terms of upgrades, i have a PSU on the way with 2x5v outputs so i can use a powered USB hub with the music files on so i should be fine for some time. Maybe when i a up to speed with all the setup etc, i will have a look at whats comes next.
Interesting thread, guys. I've been intrigued by the Pi since recently hearing one as the main source at the Neat speakers room at October's Toronto audio show. The rep, a very nice fellow from the company's UK HQ, was very keen on it. It sounded excellent. And I must say it sounded quite a bit better than his previous source (PC and DAC) that I heard at the 2017 show, playing through the same speakers. The latter made the tweeter in the speakers (Iota Explorer) sound brittle and harsh, but all was sweet using the Pi. Pretty remarkable difference.
A few questions, if you don't mind (and pardon my lack of knowledge here; I'm starting where Oliver was a few weeks ago... :) )
What are the options for user interface? PC or Mac? Tablet?
Does it sound better than a simple PC --> DAC --> Preamp setup? Reason for this question is that I already have a couple of surplus laptops, and could easily buy a simple good quality DAC for reasonable money and be done with it...plug and play, basically. But if sound quality is superior, then I'd go for the Pi.
Speaking of preamps, mine only has unbalanced RCA inputs - how do I connect a Pi to this?
And speaking of sound quality, have any of the CD players you're comparing it to been modded in any way? i.e. discrete clock boards, op amps, etc.? I have a modded Teac VRDS-10 which had these upgrades done, and it sounds outstanding. It would be interesting to know a bit more about your CD players, just as a frame of reference.
Thanks, and regards,
Svend
