Amplifiers! What do you have? What do you use?
I'm curious to know what amplifiers members use and own.
Some have straightforward choices, some have many amps, some have obscure combinations (me? :)) So tell us.
Mine, in no particular order:
Technics SU-C04 a tiny integrated that sounds very nice indeed, similar to a Sugden A21. I've owned this longer than any other amp.
Promitheus TVC paired with a Quad 306. A combo that works brilliantly. Very nice.
SMSL Mini T amp. The size of a fag packet and sounds way better than you'd expect.
Cambridge Audio P80 from the mid seventies. Bit of a classic that has a modern sound. Good bit of kit, even if it is all DIN sockets.
VTL Deluxe valve pre-amp, driving a pair of Modern Tube Classics CT15 Class A EL34 monoblocks. Gorgeous sound, great with Tannoys.
JVC AX-A441 A rare Japanese integrated with very fine sound quality. Hefty beast!
Sugden Optima 80 integrated. A little known model. Sounds rather good driving the Tannoys.
MingDa MC-9 TVC driving a Monarchy Audio SM-70. Amazingly lucid combination. Pure Class A.
Also knocking about, a Little Bear passive pre-amp, an FX Audio 6J1 valve pre-amp that cost peanuts and sounds amazing.
I've had literally hundreds of amps, but have kept only those that sound good to me.
As you can see, I have too many, so no doubt there be a 'thin down' sooner or later! :D
LFD PA2M (SE) - dual mono amplifier. Way more power and control than their stereo amps like the Zero.
Exposure IV - stereo unregulated with a massive frame transformer. This has an umbilical lead only, no RCA ins, so has to be partnered with the matching III preamp.
