STAX 500 - Five shelf Hi-Fi Stand & AV Rack Oak. Walnut or Black Gloss.
http://www.blokdirect.com/sites/defa...?itok=wfNUQVa6
"A simple and effective design that gives useful isolation across most of the audio band." - Hi-Fi Choice
The five-shelf STAX 500 Hi-Fi Stand is a solid and beautiful piece of contemporary AV furniture.
Perfect either as a dedicated Audio Hi-Fi stand or as an all-purpose AV rack, the STAX 500 is a simple and effective design, demonstrating a clear harmony between performance & aesthetics.
At home in either the living room, home cinema, music room or professional studio, the versatility and ubiquity of the STAX design makes it the perfect accompaniment to all types of AV set-ups.
STAX 500 Hi-Fi Stand Features:
- Five toughened etched safety glass shelves. Choice of black or sandblast etched.
- Each with a weight capacity of 30Kg.
- Integrated cable-management holes.
- Open-back ventilation & cable access.
- Sound isolating high-density MDF core.
- Heat resistant performance for AV environments.
- Floor height adjusters
- Choice of Natural Oak, Natural Walnut or Black Hi-Gloss Finishes. [All veneers are natural wood.]
- Simple self-assembly
"This good-looking rack is solidly constructed and nicely put together. And it helps deliver a sound with similar characteristics." What Hi-Fi.
Dimensions:
90cm [H] x 58cm [W] x 40cm [D]D
Internal shelf widths 46cm
Top shelf width 58m
Top shelf height gap 15cm
2nd shelf height 15cm
3rd shelf height 20cm
Bottom shelf height 25cm
Please refer to dimensions image for more info.
Other Wood finishes, colours and glass options:
All STAX Hi-Fi Stands are available in eight colour/wood/glass configurations as standard. Please browse through our store to see these variations or use the menu at the top of each page.
Custom finishes and sizes are available through the BLOK Custom Shop.
More product info & some FAQ's
Can I move the shelves around? Yes, the levels in the STAX range can be re-ordered to suit personal preference.
Can I add further levels at a later date? - Yes, but given that we use real wood natural veneers, there could be some variation in the wood finish between the blocks. [One solution is to order a Hi-Fi Stand that is one shelf bigger than you need, and we can supply assembly rods for each height.]
Can I order custom colours & sizes? - Yes. We can build you a custom STAX Hi-Fi Stand in just about any colour, wood finish or size, but there can be cost implications in this. [Custom blocks are relatively inexpensive, but custom glass can be.] Please visit the BLOK Custom Shop for more info on a bespoke STAX HiFi Stand.
Other general FAQ's are available to read on our site.
BLOK Solid Guarantee:
The STAX range of Hi-Fi Stands is guaranteed against any form of functional defect for 5 years.
Equally we guarantee against manufacturing flaws for the same period.
Basically, if you have a problem, then get in touch and we will sort it out.
BLOK 7 Day No-Quibble Quality Guarantee.
We believe you will be very satisfied with your STAX Hi-Fi Stand, however, if you are not then please let us know within 7 days and we will arrange an immediate refund & return.
Delivery:
All STAX Hi-Fi Stands are in stock and ready for dispatch.
Free UK Mainland Delivery on a next working day basis [subject to courier exclusions - Scottish Highlands etc.].
Order cut-off is 12pm Midday for next working day.
BLOK Hi-Fi Stands - SOUND Furniture
http://www.blokdirect.com/sites/defa...?itok=2ur7VQCK
http://www.blokdirect.com/sites/defa...?itok=Fp99XWXg
http://www.blokdirect.com/sites/defa...?itok=tOv0UttE
http://www.blokdirect.com/sites/defa...?itok=awkJflsw
http://www.blokdirect.com/sites/defa...?itok=4ds4Lt-F
http://www.blokdirect.com/sites/defa...?itok=cCvZ2goB
