Originally Posted by
Exophile
Thanks for the additional suggestions. I think for my 1.0 system, I will get something that I was able to listen to, as opposed to specs-sheet/reviews. Focal should be available, and the HF bias actually could work well with my preferences. We'll see about the others ...
Totem seems to be quite a bit pricier, so not in the running.
Dynaudio has exactly one in the price range.
Wharfedale has a bunch.
No idea whether they will be available for a listen. Things to keep in mind for down the road ...
The electrostatic speakers had an amazing 3D imaging (I think that is the term?) for singer-songwriter, so lots of mid-tones, but with electronica they sounded muffled, because they don't seem to be able to handle strong higher frequencies. So it is a limited-tricks-pony, but does very well with that trick. I am looking more for an all-round speaker. Should handle medieval polyphonics, Biber (baroque), The Ex (punkish), Sleater Kinney (garage), Austra (indie), and Mittageisen (electronica).
