I did a search to see if anyone had done any proper blind testing with fuses but could not find anything.
"if you dont believe in directionality etc why didn't you put them in the other way round? "
At that time Grant I was so sceptical I didn't bother - slightly arrogantly dismissive objectivist.
DBT is hard work, and we need a lab in which to do it on everything, but life and time constraints seem to preclude it.
Not that I am unwilling to do work on this, there can't be many people who carried a paraline along the Strand to set it up at BBC premises for evaluation, and later a pair of Tannoy Gold 15s, didn't carry those though.
I believe in cable directionality - I make up all my own cables which invariably use different connectors at each end (balanced XLR, so different sex connectors at the ends), therefore can only be used in one 'direction'. It is physically impossible to reverse them. Even the few unbalanced interconnects used in my system have different connectors at their ends.
A lot of work, or money to make two sets with opposite polarity, and then you've wasted the money on one pair until you can find a use for the spare cable.
Cables are only directional if they have different connectors at either end.
Yes, if they are only shielded at one end then there may be a better way to connect them from the point of view of shielding but this does not make them ‘directional’ per se.
The perfect cable or fuse would have exactly the same characteristics in either direction, in other words properly bi-polar. If not, there's something wrong with it!
Assuming you believe that they do, it's for one very simple reason, to try to convince potential customers that their products are better than their competitors so that they can make a profit.
If they truly had any conviction in their product they could make a very easy $1million by taking up James Randi's challenge and proving their cable sounds better, oddly not one has yet done so, surely you have to wonder why?
I have 3 sets of interconnects costing between £9 and £125 and I can hear absolutely no difference between them whatsoever
I have no problem with anybody spending their money on thousand pound cables, fuses, plugs or whatever and if they're happy with the result, good for them.
What I do object to is when they intentionally or inadvertently influence others to do the same (this isn't aimed at the OP) by singing the praises of their latest purchase as though it is factual and, worse still, suggesting anyone who says anything to the contrary is stupid, deaf or their equipment isn't good enough to exploit the difference (in fairness I haven't seen this behaviour on this forum but it is certainly prevelant on others)
